Psd fuel pressure tester gauge
Danielle
No, it's not finished
Dirty Jersey
Does someone here make the pressure tester that can do the PSD?
gnathv
Athens, Al
If your trying to check the fuel pressure, you can use a tire pressure gauge on the schrader valve on the fuel bowl. Just wrap a rag around it so you don’t get a shower.
aggiediesel01
Houston, TX
I don't know about the "correct" tester but most folks I've heard of including me replace the factory Schrader valve with this or one like it so you can use a normal fuel pressure test set. You can probably get this locally or from McMaster Car or Grainger or local hydraulic shop if you have the specs which are listed in the description if you don't have the time to wait for the mail man to deliver.
https://www.dieselorings.com/1994-1...ader-valve-fuel-injection-rated-1-8-mnpt.html
Danielle
Dirty Jersey
I have that adapter already, thought someone here made a nice liquid filled high psi tester with lines etc. But maybe I was wrong.
I try to buy local/small when I can
tke395
