Mike
I was under the impression that our trucks (GM) have seperate controllers, but the Ally computer actually controls the engine computer somewhat. Kinda backwards way of thinking. 'Course I could be all backwards myself.
Tom
I honestly have no idea what GM is doing.
Now the Ford Superduty PCM controls the engine and tranny but when doing say a Cummins or IDI conversion you would need to get a new controller to shift the tranny if staying with the E4DOA, 4R100 or 5R110 tranny.
Now the engines from Navistar, Cummins, Cat etc can be bought as stand alone engines that have the PCM mounted on the engine which is what you see in medium and heavy duty truck applications and the OEM manufacturer of the truck has to provide a certain plug on the vehicle that the engine can be plugged into.
Cummins has basicly 2 wiring diagrams for the 5.9 ISB Cummins, 1 is for the Dodge application and the other is for everybody else running a stand alone engine.
Allison transmissions have been electronicly controlled for many years before the 1000 series came out in the GM light duty trucks. They were a stand alone product and with many of the 1000 series in Motorhomes I bet some of theme are stand alone with a key pad controller.
There are a lot of custom products for swaps out there but I bet I can get almost everything I need, electrically and electronicly, right from Ford for a 2000 F-650 to drop in an ISB Cummins with an Allison tranny plug and play style. This is something I'll be checking next time I get to the Ford truck dealer in Raleigh.
I'm also going to do some measuing to see if I can squeeze an SAE3 bellhousing in this thing, If I can, my tranny options go way up and conversion costs go down about $3000
