"power plus"
dyoung14
Is getting worn out
spencer,tn
it wont feed water into it if it would i would have done killed my motor, first mod i done was ram-air, i drive threw pouring rains i can stop and the air filter is dry as a bone, just make sure the back lowest point of the air cleaner has a small drain hole in it, and everything is fine, ram-air make a huge difference in power and lowering smoke, i will kill my motor with 4000+ rpm long before i kill it because of water
93turbo_animal
Marengo,Ohio
I don't think he meant the ram air I think he ment the lid of the aircleaner if it fills up with water if the seal around the stem leaks it goes down the intake
GaryB
