langevette
Sorry for the long post but I feel ya'll need the back story
1988 f250 na 7.3 c6 claims under 100k miles
Owner asked me to help him get it started after he tried and failed. He said the trans went out so he parked it for a while. He got the trans fixed and drove it 3 days and it quite running. Found the fuel had went bad so dropped the tank changed the filter and tried to refire to no avail. A "friend" tried to help and pulled the ip, housing and all. It was reinstalled but I could tell not right as the housing had orange rtv and the timing door was black. So it was out of time. However this was after close to an hour trying to prime it and just barely got it to try to pump fuel. I had him deliver to my place so I could get a little diaper into it. I pulled the pump again and this time tried to find the timing mark. I found what I thought was a faint yellow line on the lower gear so I dropped her in and bolted her up. I proceeded to crank the engine on and off for close to 2 hours with out getting any fuel out of the pump. Out of desperation I did the gas rag trick (after waiting long enought to let the gps cool). Another bout with cranking almost 45 mins it lights on the gas and then got it to idle on its own. I tried to rev it to just hung at about a grand then stuttered and died. Tried to fire again, cranked for along time holding the throttle wide open and barely firing again. I cracked injector lines and the all seem to be working. it smokes a little blue idling
Now you have the back story, what did i do wrong?
am I a tooth off on the timing
Is the lift pump in the ip cashed
Is it both
Or something else I'm missing
Also I installed my moose pump myself and I too took off the gear housing, but got her timed with out problem but my yellow mark was very easy to find my 7.3 cranks about a half a turn and is running. So I dont think I'm a complete idiot
Thanks in advanced
Matthew
Is it both
Thanks in advanced
Matthew
