J-ROD Diesel
Hello guys! My name is Jared and im kinda new here. I have a 1992 F-250 7.3l idi and was just curious if you guys have ever heard of an idi with ported and polished heads? I have heard that scince our engines turn such low RPMs that porting and polishing doesnt really help out that much on the power side. Whats your opinions on this? Has anyone done it and can say that it was worth doing? I apriciate it guys im just getting ideas for the wish list!
Porting these heads can't hurt them be it na or turboed. Much of the gains will come from the exhaust port. As the flow goes past the seat it has to make a tight turn. That curve needs to be smoothed out some towards the coolant jacket side. The top of that exhaust port has no cooling around it and is around 3/8 inch thick. Thats the bump you see looking at the head as it sits on the engine. As posted above. The factory did a good job but flash is generally left behind restricting flow... Think of this like fingers dragging thru the water. It slows down the flow and distrubes the flow... Same thing happens with air or a gas flow. Its true that we are not spinning these engine at high rpm so not much going on in our ports.. But cleaning up the mess left behind from the manufatureing is a good idea. Also we can polish the ports without the problem carbed engines have.. We only suvk in air.. No fuel is mixed in the air charge like a gasser engine has. We wont get fuel drop out on the ports either because of this differant idea. We suck in an air charge and then inject fuel into that. Both of our valve springs are the same item. Not like in a gasser where they are differant springs with differnt lb ratings. Now think about a port or tube that has some fingers of metal on the walls. Now compress the air just on the intake side of the intake valve to 15 lbs. Open the valve and let that air pressure enter the cylinder. Now smooth out those walls with all the problem fingers distrubing the air flow at the same pressure.. You tell me which port is going to flow more air. I have tried to explain what and how it looks to me but you may have a diffrant thought too... There is no right or wrong answer to porting. I run a stock Banks wastegated turbo on a stock intake with a stock cam. I ported my heads. I'm able to cruise at 85mph doing 1850 rpm getting 18.9 mpg. My hands are thought to be magical but they are just the items I use to scratch myself.....
