Pop tester completed.
Finally completed the tester. Works great. The same injector I used to test dry actually popped off at 2300 PSI when fuel was supplied, 500 PSI more than when dry. The spray was like a fire hose tho, maybe dirt in the system.
subway
be nice to the admin :D
York PA
nice, i really like the idea of the bleed off.
argve
Resident Fruitcake
Gwynneville, Indiana
Big Thumbs up! Looks good. Now you can start modding injectors to see what works and what doesn't.....
seawalkersee
It needs a turbo...
KCMO
Thought about making one of those. Instead, I was given the factory Rotunda tester. Have not tested yet though.
SWS
nice work :) maybe a write up lol
The write up is in the Tech Articles.
Argve
I've got 40 injectors to test, be awhile, Northwest Injection wanted $25 per injector to test, that's why I made one.
Ironman03R
I gave up on mine since I couldnt get it to hold pressure. What kind of jack did you use?
Check the IDI Tech Articles.
Ironman03R
Risingsun, OH (NW OH)
I built mine like the tech artical shows and looks like the same cheap orange jack mine is built with it just wont hold pressure.
