Picked this up today
Leeland
Oregon
Free....
Awesome co-worker hooked me up with this HX40.
Leeland
Oregon
Believe it's from a ISC. As far as plans, kicking around the idea of hanging it on my truck. The GM guys are spinning them although I believe many of them are 40/35 hybrids. So I wonder why we can't do the same with the right fuel.
Devon Harley
San Diego
Needs a small exhaust housing like a 9cm or 12cm I would go 9cm an it will flow more up top an lower egt's unlike a Hx-35 with a 9cm housing run a lil higher egt's but both are a big improvement from what's there.
Leeland
Oregon
All the Cummins guys are saying a 14cm is all but non-existent let alone anything smaller :dunno ? I understand the 35 casting can be hogged out to fit and I guess would be a option but I did find a housing listed on a tuner site for the 40 and it has a t3 flange/ 3" out let that may be another option. I can't remember offhand what size the current housing is, think he said it was a 16 or 18cm.
Devon Harley
San Diego
Rub inside the exhaust port with your finger it's stamped in there. 16-18 is kinda high I think.
Leeland
Oregon
I've seen some 14cm2 thrown around on the 6.5 threads as well. Seems like they have more useful info over the dodge guys. Still not seeing any good links for finding a smaller housing. If you got any or any good tech write up's do share please.
Devon Harley
San Diego
I can put you in touch with my turbo guy he might have one. Probley need to find one burnt up or in need rebuild an grab it an pull housing.
racer30
western Oregon
I will be running a HX40w with a 16cm2 housing in my Motor Home. I want the unit to run on the top end as I will be running a Alison AT545. I know it might be a bit slow to spool but I would rather have that than High EGT's running flat out up a mountain pass.
Leeland
Oregon
Thanks Devon. Was a little busy, totally spaced having our parts department look up part numbers to see what I can get through work.
I did find the stamping, it's a 18cm housing. 8/12 count wheels.
That's also thrown around by the GM guys, hx40w and hx40wII but not really getting what the difference is.
crazytwo
SF, CA
We should put that on my DT466 and save you all the hassle of trying to make it fit.:sly
