Pedal fitment different years.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
i may be getting a entire stick shift setup from dancrowley and he has pedals from an '88, i think the cabs were the same from like '83-97 no?:dunno will '88 pedals fit? if not what years?
Thanks!
-Jon
82F100SWB
Sioux Lookout, Ontario,CA
Pedals only fit with their respective dash, 80-86, 87-91, and 92-96/7. I'm afraid you're going to need to find a 92+ set of pedals. Any manual trans truck will work though, so, it won't be tooo hard to find.
MUDKICKR
NITRO WV 25143
i have found that the pedals between the 87-91 and the 92-97 are the same, but the clutch master cyl mounts on them different. the 87-91 the clutch master cyl bolts through the firewall but on the 92-97 the clutch master cyl has 2 studs that are part of the pedal assy. you can use eithe one as long as you have the correct clutch master cyl. just found this out last weekend when changing out my trk from 460/c6 to diesel/5 speed. i have a 89 and a 93 parts trk and i am trying to use most from the 89.
EMD_DRIVER
Say what?!?!
Beaufort, SC
The 92 and up have the firewall flex problem solved. The stress is put on the pedal assembly, instead of having the firewall take the beating.
RustyNail351
