19jackal90
I havent heard much about oxygen injection... its basically the same as n2o has anyone tryd this? what about liquid nitrogen to condense air?
pure oxygen can react violently with any petrochemical including the oil left behind by the rings even. It is also expensive and you cant cary much. The oxygen in nitrous is released by the heat of compression and ignition of fuel. making it somewhat safer (at least less hazerdous to you) than O2.
Ken
ABSOLUTELY true!!!
Pure O2 and oil DON'T mix! Very scary results....
http://www.airproducts.com/Responsi...Information/safety_bulletins_OxygenLances.htm
We had this happen on an vacuum arc furnace once, cost alot of money to repair!
Those of us old enough to remember of course, know what Gus Grissom's opionion of the use of oxygen would be.
