overdrive button
GENIUSLOERTS
arkansas
Is there a fuse or relay for the over drive button? my buttin doesnt work. I picked up an extra new button to try and see if it was just the button that was bad, but the new one didnt light up either.
any thoughts?
GENIUSLOERTS
arkansas
It's the button that turns on and off the overdrive on the automatic transmissions, in my case the e4od, located on the shift lever.
Normally when you push the button, the orange overdrive 'off' light comes on and if the truck is in overdrive, or 4th gear, it will shift out of overdrive.
Fuse #17 in cab fuses. Go here to find it. http://arrc.epnet.com/autoasp/framerq.asp
Login USER IS "Bedford--------Password "library" Select "Auto repair" Go from there to select your vehicle.
GENIUSLOERTS---What does that stand for? That was my handle back in the old CB days without the LOERTS.:D
'94IDITurbo7.3
HAMMER DOWN!
Fowlerville Michigan
gonna have to give him the username and password or a link to you thread from a few days ago.
EDIT: i got it.
Everyone should put this in your favorites. http://search.ebscohost.com/ Its free for use. Just think how intelligent you can be now.
User ID--Bedford -------- Password--Library
There is loads of info there, all makes and years of vehicles. Just "CLICKY" on Auto Repair.
Administrators should put this as a STICKY in all of the forums.
GENIUSLOERTS
arkansas
pulled the column apart and found that the orange wire had been pinched between the column and shift lever.
gotta get some solder tomorrow then it will be back to good.
