one piece fuel filter
Cincinnati Guy
Cincinnati, Ohio
Picked up a new wix one piece filter for $25. Man what wonders a new fuel filter will do to your motor, now its not bogging down or anything. I guess the old filter is really old and was never changed because the bottom piece will not come off, all it does it spin and spin.
A seller on evil bay just had the top and bottom piece for our 7.3 filters up for bids... Really cheap too...
87crewdually
Southern Nj.
http://www.napaonline.com/Search/Detail.aspx?A=FIL3417_0062576299&An=599001+101990+50028+2028036
Qty Fuel Filter (Gold)
Product Line: NAPA Filters
Part Number: FIL 3417
Price: Price
Unit
36.99
Each
Features & Benefits Can Use In Place Of Part # 3217 - This Is A Complete Spin-On w/ Drain - No Plastic Bowl Attachment Needed; 12 Micron
Warranty NAPA Filters are Covered by a Comprehensive Limited Product Warranty. NAPA Filters May Pay the Reasonable Cost for Parts & Labor to Repair any System Damaged by NAPA Filters Due to a Defect in Design or Material.
Attributes Fuel Filter Gasket O.D. (Inches) : 3.6"
Fuel Filter Gasket O.D. (mm) : 91.44 mm
Fuel Filter Gasket Thickness (Inches) : .36"
Fuel Filter Gasket Thickness (mm) : 9.14 mm
Fuel Filter Height (Inches) : 4.918"
Fuel Filter Height (mm) : 124.92 mm
Fuel Filter Inlet Thread Size (Inches) : 1-14
Fuel Filter O.D. (Inches) : 4.263"
Fuel Filter O.D. (mm) : 109 mm
Gasket I.D. (Inches) : 3.2"
Gasket I.D. (mm) : 81.28 mm
Material Safety Data Sheet There is no MSDS for this item
Application Information: 1990 Ford Truck F350 1 Ton - Pickup
Engines : 7.3 L 446 CID V8 Diesel
Comments: w/ Drain
Per Car Qty: 1
93f250idi
strokin
cadiz ky
is this a good upgrade compared to my two piece with the metal bottom? its a paint trying to get that metal bottom on and off sometimes!
87crewdually
Southern Nj.
Its a good swap if you want the ease of a simple one step spin on that still has a water drain. It's all upto your personal preference.
87crewdually
Southern Nj.
do they make a one piece with the sensor port?
Geeze, u want everything:D
http://www.napaonline.com/Search/Detail.aspx?R=FIL3617_0212681820
Part Number: FIL 3617
Price: Price
Unit
41.49
Each
Features & Benefits Can Be Used In Place Of Part # 3217 - This Filter Is A Complete Spin-On With Drain And Sensor Port - Sensor Port Has 7/16-20 Threads - If No Sensor Port Needed, Use 3417; 12 Micron
Attributes Fuel Filter Gasket O.D. (Inches) : 3.535"
Fuel Filter Gasket O.D. (mm) : 89.79 mm
Fuel Filter Gasket Thickness (Inches) : 0.27"
Fuel Filter Gasket Thickness (mm) : 7 mm
Fuel Filter Height (Inches) : 5.615"
Fuel Filter Height (mm) : 142.62 mm
Fuel Filter Inlet Thread Size (Inches) : 1-14 inch
Fuel Filter O.D. (Inches) : 4.25"
Fuel Filter O.D. (mm) : 107.95 mm
Fuel Filter Style : Spin-on Fuel/Water Separator
Gasket I.D. (Inches) : 3.16"
Gasket I.D. (mm) : 80.26 mm
DOE-SST
1994 E350
I just paid 27.00 for a goldenrod 10 micron water separator/filter, and
23.00 for a goldenrod 5 micron filter, both with heads and see-thru bowl assemblies.
Oh, and $5 for the bowl wrench.;Sweet
Amazon.com
tke395
