There are three mounting bolts.
Two hold the York bracket to the A/C compressor bracket. They thread through the York bracket, the A/C bracket, and finally into the threads on the A/C compressor itself.
The last is a carriage bolt that mounts the adjuster. It fits in the 1/2 square on the PS pump bracket, then through the adjuster. The adjuster pushes the York away from the PS pump pulley, tightening the belt.
The dual groove PS pulley is found on NON-A/C Ford's. A/C trucks have a single groove pulley.
As far as a tank. It is mounted under the bed on the passenger's side. There is a quick connect on the end for air hose and a drain on the bottom to empty any water/oil.
Heath
