ok guys
scheid6996
scheid6996
i got my edge evolution, and heres the codes it throws, p1280 p0237, p1119, and p0603, what are they, and how do i fix them?
Mike
Stroker
Cora
P0237 Turbocharger Boost Sensor A Circuit Low = Possible bad MAP sensor.
P0603 Internal Control Module Keep Alive Memory (KAM) Error = That is due to hooking up your Edge to the PCM, its a memory fault you get everytime. Nothing to worry about.
P1119 MAT Sensor Fault = Open/short to PWR circuit, MAT sensor
P1280 ICP Circuit Out Of Range, Low = Low injection pressure, ICP sensor may be on the way out but more likely you are getting this code after a long pull in the throttle. Fun isnt it?
Sorry it took so long to get an answer on this. I saw the thread a couple days ago and didnt have the time to answer it properly then.
scheid6996
scheid6996
its ok thanks for the info, so for the 1st and last 2 codes, how do i fix/ check what exactly i need to take care of, anything majior to worry about?
720Diesel
