Also I read that electric sender will last a short time because of the engine vibrations, what I did was connect a hydraulic hose (Thank You Travis) to a T (I let the stock gauge still functional) and this house connects to the sender which is mounted somewhere on the fender about level with the outlet off of the engine.
