LCAM-01XA
Racer30, if you have access to the side of the oil pan you should be able to install the OEM Ford sensor, it screws in from the outside and the nut for it can be welded on the outside as well. However it may be a good idea to wait till I try it first, as if I screw up I will simply weld up the oil pan like it never happened, which may not be easily doable in a motorhome.
Jaluhn83, I'm not sure how exactly the sensor works, it's not really a float but I don't know what it really is. The EVTM is not very descriptive there, only says the sensor grounds when oil gets about a quart and a half low. My guess is at that time the sensor gets exposed to air, but what does to it to cause it to ground I have absolutely no idea. And the more I look at it the more it seems they use the sensor just as a switched ground for the relay's pull coil, while the actual warning light is hooked up to the load circuit of the relay, and the only reason to even use a relay is cause of the timing circuit which waits 5 min after power has been cut off before resetting relay (this done to allow for oil to drain back in the pan). I'll know more when I get my hands on a sensor and a relay with timing circuit attached.
