mudduck
so ever since ive turbo'd my idi ive had a pretty decent oil leak ( 1 quart a week ) so every now and again when i get some time id try to track this leak and i always thought it was in the back on the top side where the new oil sending unit threaded into the block , but last night i finally got a good enough light back there to see that it looks like oil is coming from the front of the engine and trickling down the intake valley pan then leaking down the back of the engine .
now here's the tricky part, the oil leak seems to be somwhere around my ip , but my ip also leaks so i can't find out for sure where this is comin from . some time here very soon i plan on sending in my pump to mel for a full moose kit so i was thinkin on replacing all the intake gaskets while i got the ip off but if i could fix the problem before then that would be great . do any of you guys know of anywhere that i should look first on these beastly engines?
