Optikalillushun
This is a continuation from my previous thread. Parked the truck out back and began to dig in. Following the Haynes diesel engine repair manual i have i found the following:
Checked each glow plug with a test light, all 8 were ok.
Checked continuity between the plug end and battery, all at or under 1 ohm.
Control unit ground test, .6 ohms which was fine
Supply voltage test, to power terminal 12.6v which was fine
Ignition switch voltage test, to igintion terminal 11.99v, which was fine.
Control unit function test, to the terminal with the z spring. Compare to the WTS light. Nothing. tried three different grounds with no light from the test light. the WTS light comes on for 5-8 seconds with a warm engine.
So, looks like the unit may be bad. Am i going in the right dirction? I had to come up the house to thaw out, its a little chilly out (28* lol). Funny because i can hear things clicking in the controller...Also started it up several times with success but this is with a warm engine.
