timmi
92 F-250 with banks has little or no cabin heat. Blower motor works fine. The dash temp gauge barely moves. I can get up to the lower area of the "normal" after extended driving uphill with a load. However, even when in the "normal" area, there is still no/very little heat coming from the heater core/fan...??
I have a temperature gun... where can I point to check to make sure thermostat is working correctly? Could the heater core be dirty or plugged or ?? Also, its minus-40 degrees right now, so Im sure that might have something to do with lack of heat, but still... the gauge hardly moves...
Thanks
Thanks
