All that scanner port will do is give you trans codes at best. If memory serves, the large port goes to the scanner and a power cable to the small port for the Snap-On Brick. Your antique truck does not have a PCM for engine data. Since you are after wiring diagrams, you might try alldatadiy.com and a few bucks will get you your diagram to troubleshoot.
