New to me '83 IDI for $1.00
Zbugsii
Plant City/FL
Well, as the title says... for $1.00 I will be picking up next week the truck. It is my mother-in-laws truck and for a couple of years it has mostly been sitting with them running it about 300 miles in a year. So, for the last couple of years I had been offering her $0.50 for it. This year I upped the amount to $1.00... and she decided to take it, 50% increase. Any way, this past week end I finanly really looked at the truck and went through it to make sure it was going to make the 900 plus mile trip from PA down to Fl. A lot of rust, some oil leaks, a small diesel leak.... but all in all, not too bad. I drow it around quite a bit...
But I have some questions for the forum. Now, I previously had a 2002 Powerstroke that I had made many, many upgrades and such. I also own a motorcoach with a Cummins ISL-400 engine. So I have been around Diesels... I love Diesels. So much so that everybody that used to ride in my 2002 F250 always asked me why I never listened to any music while in my truck... to which I would always answer... I do not need music when I can listen to beautiful 7.3 liter Diesel with the great turbo whine.... what can get any better.
Anyway... the questions
1. The truck water temperature just does not get up to where it should be... I asked my MIL if she knew if anybody ever removed the thermostat... which she did not know. Typically, diesels like to run at about 200 degrees. Now... though I did not spend a lot of time looking... I could not find where the thermostat housing even was on the beast. Can someone help point it out for me.
2. As I mentioned... I have some diesel leaking from what I think is some sort of return line. At the injector there is tube connected to a sleeve around it, that goes off to the next injector and so on... So, what is this, what is it called and what does it do?
Thanks
bghnkinf350
Bay Area, Ca
Welcome!
As most will tell you, if you are interested in accurate readings, put in an after market gauge. The factory gauge is not much better than a dummy light.
The sleeves you are referring to come as a kit - Injection return line kit. Talk to Typ4 for the kit.
Good Luck!
Matrix37495
The Amish Wolfman
Terre Haute, IN
The thermostat is on the pass side under the alt. Just follow the upper radiator hose. I think theres only two bolt that hold it.
USE ONLY A MOTORCRAFT OR INTERNATIONAL THERMOSTAT!
bghnkinf350
Bay Area, Ca
Sounds fair! In thias economy, making that type of profit in that short of time is almost unheard of!
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
Welcome to Oilburners.;Sweet You are definitely on the right track with your maintenance items. Don't forget the SCA additive for your coolant while you have a wrench on the cooling system. Even the 6.9 with its thicker cyllinder walls isn't immune to cavatation. I also would suggest aftermarket gauges for the temp and oil pressure. As others have posted, the factory ones are mere suggestions as to what is going on under your hood. I would service the front wheel bearings as well if you do not know when they have been done last. Best of luck with your trip.:thumbsup:
'94IDITurbo7.3
HAMMER DOWN!
Fowlerville Michigan
welcome.
i second what the others have said about getting some real gauges.
my coolant temp gauge reads cold all the time. i put in a sunpro water temp gauge and i am always at 190*F. i think my temp sensor is bad. so don't trust those gauges.
sle2115
NRA LIFE MEMBER
Southeast Ohio
Mine generally runs around 190 as well, I don't think that is out of the norm for one with a good working cooling system. Mine is also non-ac, so no restricted air for cooling...
Sounds like you got a deal, just needs a little TLC.
Zbugsii
Plant City/FL
I should have added... the first owner did install and add a second calibrated temp gage and an oil pressure gage...
So, both temp gages work... but only after I ran the truck and stopped and idled the truck for a while, it then registered some temp...
My guess is.... the thermostat is either stuck open or was removed. I will have to look into it.
Oh, another question.... any good place to get a vacuum pump... I am pretty sure it has gone south...
Thanks
