CaptainMorgan556
I've recently acquired a 1997 Extended cab long bed 7.3 powerstroke, 4x4 with and automatic tranny and she's got potential but a few problems that need to be taken care of first.
First of all the seals in the oil cooler are bad and need to be replaced, and I'm thinking of doing it myself, doesn't look to hard but I could be mistaken. Also there's a coolant leak at the front passenger side of the block where a heater hose goes to a "T" fitting and then into the block. Gotta figure hoe to seal it up the right way. After that, the dipstick tube holder on the side of the oil pan is leaking, that may have to get expoy or RTV, and I belive the timing cover there is a small leak at the bottom. Trucks got 333,000 miles on her so is there anything I should look out for? I'm replacing all my filters and fluids asap but was widmering what else I should do.
