NEW RIG!!! 96 F350 DRW 460 auto
clifdawg
Mississippi
Should get you close enough. Then just modify it to work.
I'm thinking the same. If the price is right and I'm still in need, I will most likely buy the harness from you @IDIoit when you get it out and try my hand at modifying it. I'll probably want the switches for each door also just in case.
Bako IDI
Quincy, CA
So I picked this thing up tonight DIRT CHEAP!
I've had my tab at the bar double the price.
Rather it be a diesel,
But it's a gasser :(
Needs registration, a battery and tires.
Dead stock with Alcoas
129k miles!
Set up to haul a 5th wheel
More pics in the daylight!
If you want to sell those cab over camper tie downs on the front of the bed ill buy them;Really. mine had them on it, but when I picked the truck up the guy took them off and threw them away because he thought I "wouldn't like them"......cookoo
clifdawg
Mississippi
If @IDIoit doesn't have them, I think I have a pair on a parts truck. We'll wait and see if he has his first.
mine went with the bed,
****** design IMO, they bolted right to the sheet metal of the bed.
Bako IDI
Quincy, CA
oh yea? ive seen them that bolt to the bed, and on the inside bracket they have an "L" that bolts to the frame on the bottom... obviously not as good as the ones that bolt to the frame and stick out under the bed... anyways, thanks!
tke395
