fastass350
SStock8569
I'm finally going to bite the bullet, instead of taking the time to rebuild one of my engines, I'm going to buy a rebuilt from a local rebuilder that I've dealt with many times before and trust. I can either go with a 6.9 or a 7.3, which would you choose and why? I tend to be kinda ******* my trucks, pulling and hauling, 4 wheeling and such. I always warm them up, keep fluids good and changed, and don't let them get hot.
I tend to want to stick with the 6.9 because I feel in the long run they are stronger and will last longer, less weak points. I have cores available for either, so should I go with the 7.3 since I'll have a warranty? I'll more than likely never ever run a turbo cause I hate them.
They want 2800 for a long block, which seems good to me. They always sleeve number 8 (the one that usually gets the pin hole) and everything else is new or reconditioned. That's only a little more than if I have someone do all my machining and I put it together myself.
What do you think?
What do you think?
