Need Quick Help Fender Relay?
HammerDown
Glenolden Pa
OE Ford Part # for fender mounted starter relay... need number to cross reference at parts house.
1st time ever went to start truck and just got a 'click' like bad batteries but they're new and the starter is a few months old.
With key 'on' I jumped the two large posts at the fender relay... very weak spark, tried it a few more times then it engaged the starter. My guess (hope) is, my original 1988 relay is failing.
rreegg
IDI n TDI
Puget Sound
I don't have the OE motorcraft # but from Napa it should contain ST404 like "MPE ST404SB" and according to rock auto theres an ACDelco part "F3914" which looks correct.
Per Rock auto "OEM / Interchange Numbers: 12323161, 12336881, 19106724, F903, U939" but cannot confirm these firsthand.
I replaced one year or two ago with the Napa part. Good luck hope it's resolved quickly
HammerDown
Glenolden Pa
Thank you for the quick reply I'm on the road, I can get in AC Delco, it was helpful!
If you jumped the two large posts and still had weak start, the relay isn't the problem. Good luck my friend.
HammerDown
Glenolden Pa
Not a "weak start" as it cranks hard but, a very weak 'click' at the relay... as in, not enough voltage getting to starter.
Second possibly ... the solenoid on the reman starter is already acting-up... I installed it several months ago after the original starter from 1988 was getting very tired.
Even though the reman starter is still under warranty > > > who wants to be outside, laying on there back changing out a starter in freezing weather.
HammerDown
Glenolden Pa
I'll tell what kinda stinks about owning a vehicle this old > > > when giving my Ford parts guy my vin #, because it's so old, it's invalid.
Back when I had my 1980 it was fun explaining that the vin was less than 17 characters...
Reading through this...I did a thread on this same subject.
Actually it is at the bottom of this thread in "Similar Threads".
HammerDown
Glenolden Pa
Update... I ended up using a made in Mexico relay from the brand "Standard" apparently it's more HD vs the ACDelco I was going to use.
The truck started but earlier it also started with the relay I removed ending in "AA".
Called a different local Ford dealership that went above and beyond... if this helps anyone: the top Ford # and the Motorcraft # are replacement numbers for the OE that I just removed.
Ford can get the Motorcraft # SW1951B at $70.00
One thing I did notice, the push-on 'S' terminal is much more positive and solid and that's where the relay gets its signal to engage the starter.
Only other options may be a dead spot in my reman starter or possibly the 'neutral safety switch'.
Fingers crossed that I'm good.
Indadesert
California
It’s just a standard starter relay. Same relays ford and others have been using since the 60s. Sometimes this site is too funny.
Yeah, maybe, but apparently you haven't had to buy parts for an old vehicle in a long time, you must drive a prius? You see, our trucks have 2 batteries under the hood, which produces a bunch of amps, id calculate how many amps, but I don't have enough toes and I left my abacus in my bronco. Now, I know the rest of us don't have a battery under our bed with 2/0, so we can't talk about that witchery, but the amperage and cheap China parts don't get along. So as an online community of guys that have decided to drive great looking trucks with the worst diesel engine ever made, we do discus trivial things like solinoids. Because sometimes other members have found that certain brands, even Motorcraft OEM suck. So we keep a look out for the good stuff.......
Why are prius owners on this forum?
sramasya
