Need one of these, or 2. Spacer ring
typ4
Newberg,OR
This is for an old GM bus rear engine V730/VS2-8 trans to engine spacer I could use a couple of these, some have a hole where the bumpout is. My son needs it for his 55 coach project.
Thanks
Russ I'm scrapping out a V730 tranny, do you need any parts from it. I used to get those spacers from 2 places 1 in Chicago and 1 in New Jersey, but thats been 10-12 years ago. I'll see if I still have the addresses. IIRC the one like you show is a drain back to the pan, it has a what I would say is a lip in it to catch the oil that lubes the input shaft bearings, the flywheel acts like a pump to do that. I have a bone shaft (engine to tranny) if you want it, they are hard to come by.
Don't know if you know this, but the engine rear main seal has to be changed to a two way seal when you go from manual to auto.
