Need help finding part
logonjappy
mn
I just bought a 92 f250 ext cab long box 5 speed 4wd 7.3idi motor is a different year my belt broke went and got a new belt went to put it on but the bolt on the tensioner stripped the threads out of the tensioner its the tensioner with the shock dampner had to replace the pulley did but bolt won't tighten all the way and I know its left hand threads got the belt on for now but I can't find the tensioner at any parts stores or the dealer can get it only if i pay 297$ for it and I dont want to pay 300$ for a belt tensioner if anybody has one they would like to sell for cheap or knows where to get them or a alternative solution please let me know thanks
mblaney
Ottawa/Ont/Canada
Tensioner is easily available and relatively cheap. I think you can use other models of tensioner (your's might be the exposed spring but you can use the closed). Check out rockauto... I see lots of options for way less that $300.
In your case it would be better to know the year of the engine if it has been swapped but I think all years of 7.3 will be compatible.
This might help:
https://www.oilburners.net/threads/belt-tensioner-trouble.12302/
Thewespaul
Bulverde, Texas
This might help:
Open and close spring tensions do not interchange, they use different accessory brackets
logonjappy
mn
So according to the other form I need the enclosed spring tensioner to get rid of the shock tensioner but there saying I will probably have another issue as a bent or broken bracket from my understanding let me know if i understood it right
mblaney
Ottawa/Ont/Canada
Since your busted one has a tensioner I believe you need a closed tensioner like this https://www.rockauto.com/en/moreinfo.php?pk=950716&cc=1124659&jsn=955
Yes, it is possible the shock type was installed to "solve" a problem. It could have just been a motor out of a sever duty or something (ambulance?). I don't know if vehicles came with that option or if it was a "fix" part. For the price, buy the standard closed one and try it.
lotzagoodstuff
Carmel, IN
If you want to pick one up locally, looks like Oreilly's and Napa both stock this one. For what it's worth, I've run both the shock absorber as well as the closed spring version. I think both tensioners are pretty crummy as I had both grenade on my IDI. My theory is the diesel vibration is what kills them, but thats a theory and it should be treated as such. I'd keep a spare belt and tensioner in your truck.
Good luck
https://www.oreillyauto.com/detail/...ates-drivealign-belt-tensioner/38270/4348125/
https://www.napaonline.com/en/p/NBG38270?keywordInput=38270
