Michael Fowler
While I have the engine apart for new lifters and and to re-torque the head studs, I figured I should replace the steel line from filter head to IP.
What are my options here? I prefer not dropping too much money at the dealer--I think they wanted $70+ for the steel line!
I have some copper of the correct size. Can I use that?
Should I single flare the ends and use a rubber donut like OEM? What are those little rubber donuts really called?
Can I use a ferrule and install like a regular compression fitting, or will the vibration destroy that?
I had hoped to use braided SS line, but they do not seem to connect to our compression fittings. I know I might be able to adapt at the IP, but what do you do about the tee on the filter head--that little return line?
Thanks for your help.
