Need fuel line help-quickly
tractorman86
Buckeye, AZ
If you just want to get rid of that stupid factory noise, you can do like I did here the jic 5 -orb fitting for the tailpice in the pump should be available at any stanadyne pump shop. I believe one of the guys here was trying to put together kits to sell, might want to search it. beats the heck out of that stupid donut setup that leaks everytime you have to disturb it so you have to buy a new seal -cuss buy it once and be done with it
that's me!:D :D
Diesel JD
Gainesville, FL
That hard line is supposed to have a rubber gasket? What connects to it? The hard plastic return to the tank? I've never had mine off for any reason, but its easy to make it leak at either of the small return connections...I do know that!
lotzagoodstuff
Carmel, IN
+1 on the "get rid of the proprietary OEM junk". Moving to a JIC or SAE flare is much better as you are essentially going to a 5000 psi hydraulic connetion that can be easily serviced/replaced via automotive or hydraulic sources. Whether you use hose or hard line is personal preference, but either way you are going to get a more leak free connection.
m2rtin
