smokin69
Always smokin'
Well today was a good day, I got my 86 F350 running but there's a few hiccups. It started right up on the third crank when I put two good batteries in it and hit the glow plugs for about 5 seconds before each ten second crank. It was maybe 50 degrees out and the truck had been sitting in the barn since november 07 when I got shipped off to an academy then I went to college and didn't have time for it so I'm getting it going now. I went through all the fluids and topped them off. It was running in my driveway just fine for maybe an hour and most of the smoke cleared except for when I was messing with the throttle. Anyways, I took it for a spin down some back roads behind the farm and when I got into it going up hills and stuff it kinda acted like i was pulling my foot back off the throttle and pushing it back in, it would cut the fuel for a little then go full throttle and kinda fluctuate a little bit then when I got home it would run rough while idling every now and then not all the time. I'm pretty sure I need an injection pump but I'm not 100 percent I know its probably due for one anyways at 250k with original pump and injectors. My question is does anyone know of a good reliable place to get it rebuilt or a new pump for a reasonable price and I was wondering about a good place for injectors, I believe Russ sells some good ones right? I'm also thinking about switching over to a holley red that I have on the shelf and bypassing the original.
