damac
I have been searching and reading and was just wondering if this always means a bad pump like I see mentioned too often?
I was just wondering if their pumps sat in their shrink wrap which wasn't air tight, and I only got a dribble of fuel when I installed it, could it be things sticking?
Could I try an atf soak for a day and see if something frees up or do I need to setup a return with them right away?
Truck starts right up when cold even with some air intrusion, seems to run pretty good with initial timing. Truck has fuel when warm and the starter is spinning over even faster when warm. You can just tell it doesn't want to even try to start until its cooled down.
. I know its how we test an old pump. Hot metal and cold anything dont mix too well
