SparkandFire
We're drinking beer
So, I have been troubleshooting a charging issue with the black truck since I bought it. The PO thought it had parasitic drain, so he installed a battery cutoff switch. I measured the amp draw through the switch with it turned off and was only reading about .35 amps. Not enough to kill the batteries in a couple days (as the PO said they were.)
Measured the voltage output from the alternator with the engine at high idle, only showing battery voltage of around 12.1 volts. Field wire had 12 volts on it so I figured the regulator was working.
Alternator has that burned varnish smell, so out it comes. Sure enough, I can see burnt windings inside where the field wire connects.
Since I am in a rush to get this truck running, as I have to drive the thing to work, I call the place I figured was most likely to have a reman alternator, O'Reilly's.
In stock, $92 out the door with core returned. Go down pick the thing up and bring it home. Naturally the terminal clocking was off, so I pulled it apart to reclock. The field brush is totally WASTED on this thing, burnt down to a nub, the copper wire between the brush and the holder is GONE, and the spring is totally burnt up. This is before this thing ever sees the inside of the hood on the black truck. Nope. This isn't going to be installed. Back to O'reillys I go. First they try and cop the "no return or exchange since the paint mark is broken off the housing bolts" defense. Nope. Call the manager over. he tells me they have to "send it to the re manufacturer to have it repaired for me" and that I could not exchange it. Nope. After arguing and arguing and threats of discontinued business relationships and such I get my $92 back, and my core, and head over to Winchester Auto Parts. They had one in stock, $91.20. And they swapped the pulley out for me.
Took it home to reclock it, brand new brushes and springs inside this one. New diode pack too. And better customer service. This is what I fear the most out of running older vehicles, eventually it will only become more and more difficult to get quality parts. If I had the time I would have taken it to an electrical reman shop and hard it rebuilt right...
