My 99 7.3 will not turn over, what am I missing?
Columbus, Georgia
I picked up a 99 F350 that had been parked for years. I repaired, cleaned and replaced the entire fuel system. Not to mention all the other stuff like a new starter and batteries. After all that I drove the truck 30 miles home with no issues. Then it sat in front of my shop for a few months while I decided what to do with it. It started right up and I drove it home to give it a good cleaning. It has been sitting in the driveway for about a month and will not start now. At first it dragged like it had a dead battery. Now it will not even do that. I have replaced the starter (again), solenoid cleaned the battery terminals, checked the batteries, and checked and cleaned all the grounds. It mimics a bad ground because all it will do is click one time. I have been dealing with this for over a week now. What am I missing?
did you try jumping it from the solenoid?
I had to replace the steering column switch box on mine.
Just one click and it quits, is likely losing connection. Or the starter is stuck. Hit it with a hammer.
Use some jumper cables to go from battery ground to engine block.
Columbus, Georgia
Holy crap, I did not even think to try that. Thanks, I will give that a shot when I get home.
Any idea what size the bolt is on the balancer?
snicklas
6.0 and Loving It!!
Staff member
Administrator Moderator
Greenfield, Indiana
The IDI uses a 15/16...... so that's my first guess..... I honestly don't know..... I have and IDI and then jump to a 6.0 PSD..... Only driven a 7.3PSD a couple of times.......
truckonfire
