My parts acquisitions and collections are paying off finally and I am nearing a diss-assembly/rre-assembly of my 7.3 engine soon.
Secured a deal for a complete 093 factory turbo system.... Thanks JosePedro... only taken 6 years
Have Studs for heads, need studs for main with a Girdle...why...cause that's how I roll.
Need big Pipe tap to do screw in block core plugs, or I may replace with the nice new stock ones I have with the tool sitting on bench, feel much better about threaded plugs
Have O rings and Gaskets for the Oil cooler...thanks Russ!
Have head gaskets and intake gasket...NEED LOCATE rear "A" shaped gasket for rear main cover...oh and and an installation tool for a speedi sleeve I've got the sleeve and a new rear main seal...no tool Also need front timing cover plate gaskets and maybe a WP and TS and finally exhaust manifold gaskets. That sums up sealing...Hmm
Trying to locate a small automotive propane tank to ahem..build propane injection, then a nice tank for **** too u bet I'm outta my mind.
Looking like I've got a remanned engine from the previous owner, a shortblock with heads reconditioned...about 7000 k on engine is all...Hmm..
I'll pop the injectors over the winter check heads, maybe a weeeee bit O porting and reseal em.
Every single journal will be checked for bearing clearance ...just plasti gauge but will be checked none the less.
Piston to protusion from deck will be checked....
MUST LOCATE CAM...Russ, we need talk ....have some turbo parts to trade, maybe one extra core, and one core for the cam to be ground....
OIL PUMP will be blue printed!!
Here is a question for all u whom have BUILT engines....and I'm curious on yer thoughts.
If this engine is as LOW a mileage as I'm told and is essentially just breaking in, what is yer thoughts on a thorough take down, clean, and ship out for a balance job? I'm curious cause I don't feel like buying a re-ring/bearing kit just for sake of this tear down for inspection but a balance may be affordable in all this.
Just found out $375 to balance entire engine rotating and reciprocating mass..minus the DMF, they need to determine if they actually can balance the DMF first....DOH or come up with a solid flywheel which I'm not wanting to do.
Next Saturday I'm up there to deliver trans for shipping so guess that DMF for demo I had apart is going with me! If they say yaha...then I'll use my GOOD DMF of course.
Well that's where I am, not too much involved YET.... but coming...
I know enough to leave that beast together untill all my gaskets and small parts are in hand. I can leave decisions on balance until I am into it....but for the most part, I'm damn near where I need to be to be able to break down measure and re-assemble...minus a good cam and main studs/girdle of course.
Thanks for reading
Stay tuned, this will be thoroughly documented once I start unscrewing stuff....
Thanks for reading
