6.9poweredscout
Bleeds IH red...
yep aquired a PERFECT dana 60 for $200!
it was outta a airport security truck, i don't think it was ever in 4x4!
the balljoints, tie rod ends, u joints and bearings are PERFECT! the R&P are perfect, no wear marks even, the fluid was clean, see through clean!
and it matches the rear 3.54s. so i guess it was a good find.
now the parts list! all the steering is there, but the tie rod end to the box is not there and the threaded adjuster is cut, can i just order both of them for a '93 f350? the track bar is cut, i need the bar and bracket any ideas? i'll call the ;ocal jys monday but i havent seen any 350's. there is no u bolt plate on the driver side, obviously it's different than the IFS where can i get one? and lastly will the brake/bearing/calipers work off the IFS? the bearing nuts are gone on the driver side.
pretty mch this should bolt in then right?
Thanks guys!!
-Jon
Thanks guys!!
-Jon
. A&A was closed but i'll check tomorrow.
;p
