MURPHY IS A HUGE TOOL!!!!
hesutton
The Anti-Anderson
Bowling Green, KY
Not saving the clutch swap for the week before the rally are ya Ron? I know how you like pre-rally truck jitters!:D;Poke
Heath
Dsl_Dog_Treat
Decatur,MI
Heath
I'm thinking about it Heath. With the way work has been in the shop lately, I may not have a choice. :D
hesutton
The Anti-Anderson
Bowling Green, KY
Unfortunately, I didn't get the truck done this weekend. But, I got dang close. Another stop at the office by Murphy is part of the problem!!!:mad: I was crawling under the truck to put on the freshly hammered ZF5 dust cover when I noticed a bit of coolant. :eek:
I saw there was coolant leaking from around the anchor screw on the block heater. I never touched the block heater when I had the engine out. I thought it may just be loose, so I tried to tighten it down. It wouldn't tighten at all and the leak got worse and worse.:backoff
I had to drain all the coolant, drop the starter, and remove the block heater. Sure enough, the butterfly nut on the back of the heater was split in two. Lucky to find it now rather than on the road and after I lost all the coolant. And lucky me, I had an extra block heater........ used but good! I put the spare heater in and it hasn't leaked a drop since.
I still need some new CAT batteries, and to finish up some wiring and reconnect some vaccum stuff, but that should be it. I'll post up the finished product when the time comes. I've got to bust my hump though as I'm on time crunch.
Heath
gonecrazyi
florida
Its always something. I put 325/85/16s on my truck and ended up using to trim one fender and hit the spring on full trunk on the other side.
tke395
