MPG Question
oilburners
Beverly Hills
My NA must be setup right. I got 23mpg on the highway at 55mph. 437 miles on one tankful. That's with rest stops and a couple miles of city on each end of the trip. Tires, gears, acceleration, speed all play a part. Mine has 4.10's, I think it's one size up over factory tires, and you have to drive like an old lady. I figure I'd get 13mpg if I drove like a maniac and that trip would have cost what - $40 more than it did?
david85
Campbell River, B.C.
Mine will consistently deliver 20 MPG @ 70 MPH but short trips around down bring it as low as 13 MPG on some days. Generally I run the trip meter to 500 km (305.5 miles) on the front tank and 450 km (274.95 miles) on the rear and that allows a solid 10L (2.65 USG) safety net usually.
I've never run either tank dry on a hypermiling (55 MPH cruise speed) run but in theory, that would get me a range of 528 miles on 22 gallons of fuel assuming 24 MPG (tests returned 24.4 and 24.8 consecutively). It *might* be possible for my truck to reach 1000 miles on both tanks if conditions were perfect.
fury9
island lake il
if youre gonna time it without a meter- there should be two alignment marks one on the IP one on the housing from the factory. when I timed mine (with a meter) mine ended up being about a dimes width (advanced) when done, from factory marks. I took a chisel before I even touched anything and made a mark of where it was. Like someone said before" timing can make a difference between a truck you love and a truck you hate" ( something like that.) But I could get about 14 out of it (c-6) 3.55. with the e4od and the 4.10 (which if you're not using they are killing your mileage) you are probably at what you can expect. mine was so far retarded I had to use a crowbar to twist the IP far enough to get it right.
Cincinnati Guy
Cincinnati, Ohio
Will I need to advance or retard it to see if it will help with starting and MPG.
Oh I dunno if this is relivent information but I can stomp my pedal going up a long hill and will not get any smoke.
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
With my old motor I always netted 14-15mpg around town, kept a log of it actually. I moved furniture out of state for a family member and netted 357 miles out of my front tank and 18 gal filled er up. Thats 19.8 mpg and I was estatic. This is with the Logger, you can see the specs in my signature.
HankHill
NY
my truck gets 13.4 mpg average, town and highway mixed, I'm sure with a new IP and properly timed pump I would get another 1 mpg, my truck is also timed by my ears haha
grog85
novi,mi
Mine has varied between 12 & 21 between different tankfuls, and the blue-gray smoke varies too. I think my injector pump is finally on its way out.
Cincinnati Guy
Cincinnati, Ohio
Still have not messed with my timing yet, been chasing down other little problems. With it being a long week and Im on vacation I plan on getting this done and re checking my fuel mileage. So which way should the IP be turned? Im not sure if I need to advance it or retard it to get better mileage.
Ive always thought that if you stomp the go pedal you can expect a little black smoke, but when I do it nothing at all comes out. Im not sure if thats telling me anything or not.
oilburners
Beverly Hills
I'm thinking that hiring someone with a dyno and experience might be the best way to tune my truck. Peak power + no black smoke. Let us know if you figure out which way to turn the pump for mpg. Someone messed with my new one so much I don't know where to begin, if it was stock at least I'd know where I was starting from.
dyoung14
Is getting worn out
spencer,tn
Im really lucky to make it to 200 miles on a full tank, i have to fill up twice a week:puke:
Diesel Max
93 F-250 4X4 - 7.3
New Mexico
I can get about 240 out of my front tank with mostly highway driving at about 70-75 MPH........
Rot Box
Northern Utah
Lewiston
So far I have only been able to dream of 20mpg or higher from my truck! LOL
My truck is a 4x4 long bed crew cab so that factors in I'm sure but I usually switch from the front to the rear tank @ 210 miles and that is just above 1/8 tank. My speedometer reads five miles and hour faster than I am actually going too so that doesn't help (or does help depending on how you look at it :rotflmao). Last time I checked my mileage based off GPS I came in just below 16mpg on the freeway doing 65-70 the whole time...
I think my 3" exhaust is restricting it a bit--maybe I could squeeze out another mpg or two with 4" :dunno Anyway hope this helps.
crispy74
