So far I have the rotating parts assembled. The pistons are between 0.024 & 0.026 above the block deck. Now this is after I milled 0.010 off the top of a set of Mahle Ha pistons that were already low comp (pins milled 0.010 higher in the piston) pistons. Then I had them coated with the Tech Line CBX creamic for high compression engines. The balancing went fine after I balanced all the pistons myself. The shop I used told me it would be ok if I could get them down to a 2 gram differance. I was able to make them between 1/2 and 3/4 gram in my shop.... The heads are on but like I told Mr. Bill last night I'm not looking forwards to the final 2 line patterns at 110 lbs each. I really hurt so much and I know this will make more pain in my back but it will get done. I just need to step up and do it and be done with it. Its not that I don't have hte offer of help because I do. Its just my responsibility to get it done. I think I'll put a cheater on the end of my click torque wrench..
