redneckaggie
rebel w/o a cause
I have noticed truck seemed a little dead in the mornings when I went to start it(rolling over a little slower and lights are a little dim. I went to have my batteries tested at oreillys and I only disconnected one ground wire and one of them tested bad when on the truck. so i went to get a battery and after buying that battery I had carquest test the one that oreillys said was bad for laughs. It tested good on their tester(in house) so I hooked it up as a third battery. On the way home from work yesterday My battery light came on but the gauge was still saying I have charge. when the batteries were tested I know the voltage on all of them was almost 14 volts so Im thinking voltage regulator.
can I just use my multi meter to test the voltage off the hot post off of the alternator to check the voltage regulator?
I also used silicone spray when re doing the batteries and it got on the blades for the voltage regulator so i dont know if that would mess things up?
