gatorman21218
Well to continue the saga my front brakes are now dragging heavily. I would really like to talk to someone over the phone. If you are brave enough to help me could you PM me your phone number thanks
if you're using a FSD master, you should have no pressure issues.Yeah i guess verizon doesnt have any towers on orb union
Ok I talked to russ this morning. I am replacing the rubber and steel lines for the front. The calipers are dragging so im going to replace them too along with new pads. its only money right? Russ mention the pushrod situation and I checked i can mount the m/c against the booster with no trouble so i dont think its forcing against the m/c. The push rod is a little too thick to fit nicely in the hole on the booster. Is this ok or should I grind it down so it can bottom out it the booster? BTW I am using a F-superduty Master cylinder.
lol
