Dirtleg
Not for me but for probabaly alot of you.
Today I had to put some new o-rings in my fuel line from the filter to the injection pump. I used trade size # 011 orings if anyones interested in knowing.EDIT(note; these are a supplement to the worn down rubber inserts already in there. Probably not a correct fix but working for now)
Back on topic. When I was finished I bled the fuel system like I have done before; crack open all the injector lines at the injector, crank in 10-15 second bursts with 1-2 minute breaks in between until there is fuel at all of the injectors. Then tighten all of the lines and you are good to go.
So I did exactly that but I was not good to go. In fact there was no go at all. Just more cranking. I was to say the least confused.
So I re-cracked open all the injectors, wiped all of them dry, and cranked again. Immediately they were all wet again.???? Now I was really confused. At this point I said what the hell and decided I would just waste some fuel and make sure they were good and bled out. Then I re-tightened the lines.
Still no starting. Now I was wishing I had some ether. I did this with the motor hot thinking it would be easier to start when I was finished but I guess not. My batteries, which had performed valiantly up to this point, were beginning to weaken so I had to get out the jumper cables and find an unused forklift to hook it up to and let it charge.
I once again cracked open the injector lines, all of them each time, and did a little cranking. I then tightened them back up and cranked some more. Eventually it started, stumbling badly at first and then finally smoothing out into it's normal good idle.
So for those of you that have had a hard time bleeding your fuel system a time or two don't worry about it. It's a normal occurance. I have bled it twice before without any drama. Today was different even though I used the same techniques. Go figure.
To make matters worse I had to take my Dad to the airport and was afraid I wouldn't get it started in time. It all worked out however.
Electric fuel pump is looking better and better all the time.
