65sixbanger
Ok I shouldve known better than to put this pile o s*&t dmf in my truck but I did so now I want to reduce the clattering noise it makes. I bought with the ZF and I just assumed it would be ok, but you know what happens when you ASSume. I guess the only problem is that it clatters, but when the windows are down it is kinda annoying, and really its only at idle, take-off or slow speeds. I dont want to pull the tranny in this weather, so I was just wondering if welding on it would cause it to flex too much. I was thinking it would, but I have a perfect angle at it with the inspection cover off and I could put a solid bead on it. 12" x 3.14 is about 36'' of a bead so I know that hold up.
Any thoughts?
Any thoughts?
