MUDKICKR
what i meant by what i said is if you set the flywheel down you can move it in and out a little. if you weld it off center it can viberate and tear up the clutch. the clutch disc side of the flywheel attachs to the crank side by a bearing. that bearing even new will have some play in it. so if welded off center when you let out on your clutch it will feel like its coming apart. im not saying its going to be out of balance due to the welds, just that if welded off center then its going to have some bad things happen in short order
, well maybe I will just do the lucky mod when it gets out of the forties!!
