Missing after turbo upgrade
Chasbeau
Newport, Oregon
I have a '97 Powerstroke. I had a reputable turbo shop upgrade my turbo and after installation my 7.3 started missing under load. It's worse after it's warmed up. Fuel pressure is a little low. Under a heavy load it has 19 lbs of boost at 1200 EGT. I have a TS Performance 6 position programmer set at 75 HP. Is the fuel pressure the problem? It didn't miss prior to the turbo change.
What are you reading with?
Sounds like that might be the ICP reading. Which is low. So I would say sounds like bad injector orings.
Fuel pressure has to be read manually with a mechanical gauge. Should be about 55-70 psi.
