needlenose
Can someone describe how to measure correctly turbo shaft play? I put a mag base on the GP controller mount and used a dial indicator on the tip of the shaft. I measured .017" of deflection. But the indicator has to be angled into the inlet in order to reach the shaft; so it doesn't seem like the measurement will be accurate. How is this normally done?
Also, I ran across this while looking up how to check shaft play. I know very little about turbos, but is this guy serious? My turbo has no where near this much play. Mine can barely be seen with the naked eye.
https://www.youtube.com/watch?v=q3a4D4uUjQo
