The use of this tool is no different from the Snap-On mt257 or the Ferret model. If you have a 7.3, locate the line that has the "adapter" between the line and the injector. On the pickup truck system, the line right under the feul filter is the one. Here's a trick I do, take a small piece of sandpaper and remove the paint on the line closest to the injector, this will help it ground easier. Loosely clamp the piezo adapter on the line and attach the wires. the positive will go on the piezo and the ground can go on any bare metal part on the injection pump. fire up the motor and check to see if the light on the meter is blinking steadily, gently tighten or loosen the piezo until the reading is steady enough for the timing light to accurately measure a RPM. At that point, check the timing at idle. make note and rev up the motor to 2k rpm. check timing while it's at 2k rpm. There needs to be a minimum of 2 deg measured from idle to 2k. if in need of adjustment, adjust the pump accordingly.
