I'm less than happy. Installed my Luk SMF. Went okay. Go to install the pressure plate. No Bueno.
Here are the packages the bolts came in. They both clearly say torque to 45-49 ft lbs. flywheel bolts are 3/8. I could by that for them. I set torque wrench to 47. No problem. The pressure plate is 5/16" bolts. 45 is a lot on a bolt that size. Ford service manual calls for 15-20 ft lbs on those bolts. I figured, well, it's aftermarket, should go with what the package from the manufacturer says right??
Not so much. The good news is that I got the broken bolt out of the flywheel.
So now *** do I do. I'm hosed until Monday at this point. Parts stores have nothing. Can't talk to CS anywhere till Monday. The thing is, I'm afraid to put the others back in there now because 1 broke and it seems like there were others that were stretching so I really need an entire set and I will not torque them to that spec, I don't care what the package says.
So here is my plea. Anybody have any idea where I can get such a thing? It's a 5/16-18 x0.95 as per the package. Closest thing I have found is this.
Mr. Gasket 911 Pressure Plate Bolt - Set of 6 https://www.amazon.com/dp/B000BWAOU8/ref=cm_sw_r_cp_api_QCVIxbSNWRH2X
Any other suggestions??
Thanks guys and gals.
[emoji20]
[emoji20]
)but apparently missed a few sets. He was impressed that I got all but 1 torqued to that value though.
