Lucas Trans Stop leak and the C6
WrickM
Richmond VA
So i noticed i had a little seapage from my transmission cooler. Working two jobs now i don't have a lot of time for. . . anything. So i decide to try the lucas transmission sealant stuff. It (a lucas addative)worked for my power steering so why not. So i top of the fluid in the transmission (which is still crystal clear and red :thumbsup: ) run the truck around a little bit, then add the lucas , run it around some more and let sit overnight. I haven't noticed any leaking, but it was very slow to begin with, but it does feel like the toque converter is a good bit tighter. It makes some sense given the very Thick addative, but has anyone else noticed this? It's an improvement in the drive. Unless someone has missgivingsi would recomend it to others.
ihatelaramie
Sugar Land, Texas
I've used the stuff before in a couple of my old trucks and my results were mixed, though none bad. One truck, it made no difference, but in the other, I experienced what you've described. It may have been all in my head though...
Vinceslamer
