Welp...this is uncharted waters for me
There is play in my steering column (I can feel it when I lift the steering wheel up and down) and I'm wondering if I should worry about it or if there is a way I can tighten it back up? I'm assuming there is an upper bearing retainer or something that has worked loose. Everything else feels tight and it steers fine. Thanks for any help you guys
It is a non tilting column other details on truck are in my sig...
. I have tried to change the bearings but with no success. its just all worn out. It needs some major work under there. That is actually the last piece to make my steering and suspension 100% new
