Mr_Roboto
I get a set of new Standayne "G" code injectors and installed them yesterday (along with a NOS reman IP and GP's).
Well I run to one of my customers and when I stop I hear a hissing noise. There is air and fuel spraying out of every hose and gasket on my fuel tank.
Turns out Stanadyne didn't tighten the nozzle on the injector, which mean there was no spring tension on the pintle, and the injector was letting combustion gasses into the return system. The nozzle was only about 1/2 turn loose, which is apparently enough to wreck havoc.
I'm real unhappy with Stanadyne for letting an injector leave the plant partially assembled. Plus the money I lost with the truck being down PLUS my customer (a repair shop) seeing my truck ******* diesel all over.
I'm sure this was a one in a million thing, but just check your nozzles before installing injectors. The nozzle will turn easily if it is not torqued down on the injector body.
