Dsl_Dog_Treat
Well,
I got a chance to start playingwith Goldilocks tonight for a couple and found the carrier bearing and spline shaft on the rear driveshaft loose and very sloppy.
The carrier bearing seems to be pretty soft and there appears to be some play in the splined area. Could this be caused by the carrier bearing going south or combination of both being worn? There is quite a bit of vertical play on the rear driveshaft causing some vibration and a clunk when taking off or changing direction.
Any thoughts before I start changing things out?
Ron
Ron
Hmmmmm.
Dangit Mel,
thats good mel
